Front pully on JD LA
Jeff Oliver
11-20-2002 13:59:50
We are just finishing a LA that we recently bought and noticed that the front pully was really loose. Thinking we could just put a bushing in it and go on we found out that the shaft is tapered. The way we check it it seems to have a taper of about 1 degree per side or 2 degrees total. Does anyone know if this is correct?
Thanks!
Dwayne
11-20-2002 18:21:09
 Re: Front pully on JD LA in reply to Jeff Oliver, 11-20-2002 13:59:50
What you have seems to be a common problem. the crank shaft is supposed to be straight, not tapered. the pulley has worn the crank.the only options are to have it welded and turned back to standard, or you could try a bushing. It doesn't sound like yours is worn that bad, so you might be able to get by with just putting a good pulley on it. alot of people leave them loose if it is an electric start tractor.
Dwayne
11-20-2002 18:24:18
 Re: Re: Front pully on JD LA in reply to Dwayne, 11-20-2002 18:21:09
sorry for all the replys, my computer kept messing up and didn't think it was going through
jeff
11-20-2002 20:40:53
 Re: Re: Re: Front pully on JD LA in reply to Dwayne, 11-20-2002 18:24:18
no prob on the replies. Mine did the same thing this afternoon and I got griped at for posting twice .Oh well:) thanks for the info though, looks like we might get to take it out and fix it then. Luckily My dad and I own a machine shop so that part of it is easy.
Of course it might be just as easy to put the hand crank motor back in it since the pulley on it is tight. As long as I can get my son to do the cranking I don't see a problem with this..LOL!!!
Thanks for the info!!!
Dwayne
11-20-2002 18:20:43
Dwayne
11-20-2002 18:20:15
Dwayne
11-20-2002 18:20:05
