4010 Synchronizers
Scott
11-20-2002 12:40:29
I recently purchased a JD 4010 to use a little around the farm. Doing a little work to it to dry up some seals and such, and found a piece of what seems to be a synchronizer/spacer in the bottom of the tub when I drained the rear end/transmission. I have another trans from a pulling project and the best I can tell, on each synch pack, there are 3 clutch?? and two spacers. Is this right? Looks like all the stuff is in the one I am working on now, but the piece I found concerns me. Only other thing I can figure, is that they might have been changed at some point in time, and the piece was never retrieved from the bottom of the trans case.
Also, when tractor is in 7th or 8th gear, makes some noise. Doesn't do it in any other gears that I can remember. Sounds like coming from the rear end? Is this normal, or what could it be?
Thanks to all for the insight!!
