Clooney, Gotta laugh. If the airplane throttle stays constant, then you've never ridden with one of us fighter pilot wannabes! My JD is the set it and forget it throttle! Understand we're talking about external versus internal frozen water. So what's causing the carb housing to be cold and therefore frost on the outside? I'd think pressure differential as a single causal factor would cause frost to extend a ways into the intake runners, and maybe a ways back up the air cleaner tube. It does extend a fair ways on the coils of air conditioner; admittedly probably a greater pressure differential. As it is, the only place I've seen it is on the body of a carb. Usually right around the body of the throttle, down to the bowl. Your 65/40 observation is fairly close to the 20/20 rule they preach in flight school. That is, if temp and dew point (I think dew point is about the same number as % humidity at that range) are within 20 of one another, watch out for icing. I'm assuming an internally icing carb frosts up on the outside as well, just as a glass of ice water causes condensation on the outside of the glass, or frosts in your hand at a football game, but have never had much taste for sky diving or wing walking -- so don't know. Sure is a common sensical sort of idea, though. Occurs to me maybe we're talking about the same effect at widely spaced parts of the scale. The air density at 5,000 feet at constant temp, dew point, and a constant 30 inches of Hg altimeter settings is a 1:.85 ratio. Said another way, we're 820 ft above MSL here. JD's don't fall out of the sky with frozen carbs, don't even stop running on the ground (we hope). At 65 temp, 40 dew point and 30 in. Hg we're 96% of MSL air density here. If we move the JD to Leadville, CO. - about 9600 ft. above MSL - the same temp, dew and altimeter settings say the air is about 7 tenths as dense as sea level. Relative ambient air density may account for the differences in degree while the effect is the same in kind. Been a long time since I took physics or knew Mr. Bernoulli very well, but I'm assuming pressure differential will stay constant if not shrink as altitude increases. So you borrow some Doc's laser spectroscopy gizmo and see if that hole / orifice (redundant? -- borrow the proctologist's gizmo, make it even sound worse) freeze up in there. Meanwhile I'll take up wing walking and see what happens to a carb at 10,000 ft with 20/20, no carb heat, and no touching the mixture control. Or, we find somebody in Leadville, CO with a JD and he can figure it out.... Steve
