DLTX 71 vs 72
Todd
11-19-2002 21:12:38
I realize that the 72 is an all-fuel, and the 71 is a gas, but what are the differences in the two? Will one outperform the other in stock fashion as far as running or power? Thanks
Clooney
11-20-2002 07:39:04
 Re: DLTX 71 vs 72 in reply to Todd, 11-19-2002 21:12:38
Todd, the big difference is the 72 uses a tunable [replaceable] economizer plug & the 71 uses an internal [fixed size] economizer orifice.
~The 72 was designed to meter heavier fuels than the gas only 71.
~As far as power goes, you should probably ask the pullers over on the puller board. I haven't ever dynoed the 71 v/s the 72.
~You might want to call Roberts Carb, I'm sure Robert could tell you all you needed to know + some....
