Inlet pipe on '48 A
PeteNy
11-19-2002 16:35:40
Guys, Have to replace the inlet pipe on our '49 A...doesn't appear as easy as it was on the '50 B because the fanshaft is in the way. Looks like I have 3 choices: 1) unbolt the fanshaft from it's front support, remove the radiator shroud, and try to lift the fan shaft enough to get the inlet over the studs...will it clear? 2)Attempt to remove the studs, but there isn't much room to get on 'em with the inlet in place. 3) Break down and remove the governor and fanshaft. Any ideas? thanks, Pete
