JD 265 FRONT LOADER
RAD
11-19-2002 15:33:40
I need some information about a JD 265 front loader. I have not been able to find any site that has specs on JD loaders. Is this one too heavy for my JD4020?
Gary in TX
11-20-2002 21:27:56
 Re: JD 265 FRONT LOADER in reply to RAD, 11-19-2002 15:33:40
Hey RAD,
I have a 48 loader on my 4020 and I can't say enough good things about it. Don't know how I ever got along without a loader? A 148 would have loader arms in about the same position and the view is still very good from the seat. If I had a preferance I would rather have a 148 but the 48 was on the tractor when I got it this year. Bush hog makes some good looking loaders as well and you should be able to get out for under $4000 bucks. Hope this helps in some way.
jd730
11-19-2002 19:21:55
The 265 is a very good loader, it was designed for MFWD tractors. It will fit your 4020 with rowcrop mounts but will stick out front a long ways.Find a good 148 it will make a nice setup with your 4020. Later Bill
Chris
11-19-2002 19:17:37
The 265 is made for the front wheel assist FWA models, thats why the loader frame sits so high, I would say it should fit but would be overkill for your tractor also the frame work obstructs alot of the operators vision even on the FWA models, thats my 2 cents hope this helps chris
