Compression Options?
Model A
Kenny
11-18-2002 19:09:35
I have a Model A which I was told is the high compression model. Did they come with a choice of compressions or were they all the same?
G Taylor
11-19-2002 08:36:48
 Re: Compression Options? - Model A in reply to Kenny, 11-18-2002 19:09:35
Model 60 LP pistons fit right into a late A. Just make certain the block and head surfaces are flat and all fasteners are sound on a late A or any 60 no matter what the compression ratio.
rollo
11-19-2002 05:31:43
Some of the "A's" had "high altitude" pistons that compressed the mixture more than normal. I put them in mine to increase the horsepower, however slightly.
Steve - IN
11-18-2002 19:40:47
Kenny,
The late model gas burners came with about 6:1 compression ratios and the all fuel or kerosene burners were about 4.5:1 from the factory.
The early A's had 309 cu. in. engines instead of 321 cu inches of the later models.
Someone could also be talking about an aftermarket hot rodding kit, but chances are they're saying yours is a gas (single tank) instead of an all fuel (large kerosene and small gas tank).
Steve
