JD G weight
NY Farmer
11-18-2002 18:39:31
I know this question has been asked about 30 times but I could not find it in the archives, is it possible to get a 47 JD G in the 5000lbs class or not?? let me know thanks
2 cylinder
11-19-2002 08:07:20
 Re: JD G weight in reply to NY Farmer, 11-18-2002 18:39:31
In order to get to 5000# you'll have to take off anything that is not needed, like your oil bath intake system, your generator, radiator shroud, rollo-matic front end, go with pressed wheels and a flat back, and smaller front wheels and tires, and a light driver. If your running a magneto instead of a distributor you can pull your battery after you start your tractor.
I have not pulled my 51-G in a 5000# class yet, but figure mine is close as I have to add quite a bit when pulling 5500#. I pull a 47-A in 5000#.
JohnDeere2Cylinder
11-18-2002 19:27:01
I pull with a JD G about the same year. Little 12 inch front wheels, 16.9 x 38 pressed steel on rear, front and rear weight brackets made from 1/2 x 4 inch steel, steel adjustable anti-roll bars, no power take off, homemade steel flat back, small battery box, adjustable height rear hitch. Tractor weighs 5050 pounds, 5250 with me on it.
