JD 290 / 490 planter
Darrell Eichhor
11-18-2002 07:19:40
I'm wanting to plant about 10 acres of pumpkins and I understand that these planters will do that with the right plates. Any body know about this or if there is a planter set up for planting pumpkins squash, gourds and melons. Darrell
[email protected]
Leroy
11-18-2002 16:06:05
 Re: JD 290 / 490 planter in reply to Darrell Eichhorn, 11-18-2002 07:19:40
Years ago we had a 246,(2 row 3 pt. hitch) planter and we put out a lot of pumpkins,We put them in the corn field so instead of using the seed boxes for the pumpkins, (corn was in the seed boxes) we mixed then in the dry fertilizer in the fertilizer boxes. All J. D. plate planters except the 2 row horse planters and they could be changed over use the same plates
Steve - IN
11-18-2002 10:24:10
Darrell,
I don't find pumpkin, squash or melon seed on the 290 plate list, but here are some plates for seeds that might compare in size:
uH 1239B large sunflower seed
pH1319B shelled jumbo peanuts
pH1282B Navy Beans
At the bottom of the list, it says consult your John Deere dealer for other seeds not listed -- that may be the smartest thing to to.
Steve
Steve
11-18-2002 13:34:07
 Re: Re: JD 290 / 490 planter in reply to Steve - IN, 11-18-2002 10:24:10
Does the 490 take the same plates that the 290 takes. I found a pumpkin seed plate for the 290. Darrell
Steve - IN
11-18-2002 14:26:18
 Re: Re: Re: JD 290 / 490 planter in reply to Steve, 11-18-2002 13:34:07
Darrell,
The 490 is just a 4 row version of the 290. All the parts I see are interchangeable. I'd guess your odds are better than nine out of ten that it will work. Funny thing is I don't see any pumpkin seed plate listed in my 290 parts book or manual. Go figure...
Good luck with the pumpkins.
Steve
Darrell
11-18-2002 15:08:58
 Re: Re: Re: Re: JD 290 / 490 planter in reply to Steve - IN, 11-18-2002 14:26:18
Steve I checked with a JD dealer and he can get the plate # B27436 for a 290 planter. It said that it was for planting pumpkin seeds. Also is the 490 the same as a 494. I saw one listed. Thanks Darrell
Ed
01-12-2004 17:03:47
 Re: Re: Re: Re: Re: JD 290 / 490 planter in reply to Darrell, 11-18-2002 15:08:58
You will need part Y2630B and Y5064B also for each hopper. This is from the JD seed Plate Parts Catalog.
Steve - IN
11-18-2002 16:18:38
Darrell,
You've gotten too new with a 494 planter. The 490 was discontinued in the late 50's and the 494 was built in the 60's and 70's, I think. It surely looks like a different mechanism than the 290 I grew up with, but don't really know for sure if the plates will interchange. Sorry - gonna have to punt on that one.
Steve
Ed
01-13-2004 13:53:45
 Re: Re: Re: Re: Re: Re: JD 290 / 490 planter in reply to Steve - IN, 11-18-2002 16:18:38
All open center JD seed plates are interchangable....
Darrell
11-18-2002 18:42:47
Thanks for all your help. Have you heard of a Cole planter a 12mx? It was made for vegetable planting I believe. Darrell
Steve - IN
11-18-2002 19:00:19
 Re: Re: Re: Re: Re: Re: Re: JD 290 / 490 planter in reply to Darrell, 11-18-2002 18:42:47
Darrell,
Yes, they're from the South. Mostly associated with tobacco production; in my mind anyway. That's a single row planter, but looks like it's an orphan now... here's the link to info on their web site.
Seve
Darrell
11-19-2002 20:00:09
 Re: Re: Re: Re: Re: Re: Re: Re: JD 290 / 490 planter in reply to Steve - IN, 11-18-2002 19:00:19
Thanks for your kindness. Darrell
