Antifreeze in #2 Cylinder
Blake
11-17-2002 19:22:13
While replacing the water jacket to block gasket, some antifreeze fell into the spark plug hole in the #2 cylinder, it is not very much, maybe a 1/4 cup at very most. How can I get this out and and prevent it from hurting the piston, and cylinder wall. The engine is in real good shape and is all intact, I just have the tractor broke down except for the engine, tranny, rear end, and powr-trol. I really don;t want to have to take the head off, does anyone have any suggestions. Thanks very much, Blake
zane
11-18-2002 16:25:19
 Re: Antifreeze in #2 Cylinder in reply to Blake, 11-17-2002 19:22:13
If the starter (or your arms) will turn it over, there'll be no harm done. Antifreeze is not corrosive to steel. It'll dilute your oil a little but your engine won't notice it. If you can't turn it over, remove the plug and then do it.
Ralph
11-18-2002 16:05:24
Tape a short piece of copper tubing into the end of your shop vac hose. If a cup full ran in, I'm not sure you want to bring it up on compression, if that is the first stroke.
sam
11-18-2002 15:42:26
I wouldn't worry about it. When the tractor gets started it will blow it out!
Dan
11-18-2002 06:22:26
Perhaps a small syphon hose could work for you and then shoot a little air in there.I don't think a small amount of freeze will be too bad.
Blake
11-19-2002 19:28:52
 Re: Re: Antifreeze in #2 Cylinder in reply to Dan, 11-18-2002 06:22:26
Thanks for all the help, I remembered the petcocks on the bottom of the block. I opened them up and then rolled the engine over and the antifreeze just shot out like a high pressure washer, I rolled it over for about 10 minutes in make sure I got it all out. Thanks for all of the help. Blake
