4020 upgrade to 4430 or 4630
Steve
12-27-2003 17:48:42
I have a 1965 4020 diesel row crop that is in very good condition but it does not have enough horsepower for some of the ground working that I do. I am also tired of being out in the open and would like a cab. I am thinking of a 4630 or 4430. I know the 40 series are stronger but they are out of my price range. I think I can buy the 30 series for little more than I can sell the 4020 for. What are the pros and cons of the 4630 or 4430? The 4630's I have seen have been cheaper than the 4430's. Is there any problems with them? Did the later years have an updated rear end? I have heard of the problems they had.
Dan
12-28-2003 10:52:56
 Re: 4020 upgrade to 4430 or 4630 in reply to Steve, 12-27-2003 17:48:42
I worked for a JD dealer at the time the 44 and 46 were new. There was a problem with in the rear axle area on both I believe but there were updates JD installed for free. There was also a problem with the perma clutch on syncro and quad range but this too was taken care of by JD updates. I agree that the 44 is a more all around tractor for general work. Depends upon what you want to do with it. In our area I never heard adny complaints about 44s but we have very few 46s here. If in good shape it is tough to find a better cab than the soundguard.
John Jenkins
12-28-2003 09:13:58
Buy the 4430. The 4630 is 150hp compared to the 44�s 125 but the 4430 is a much better all-around tractor. We bought a 4630 and a 4430 new in about 1975 and we ended up trading the 46 for a 7520 about two years later because it couldn�t do any more work in a days time than the 4430 could. I know you said the 40 series tractors are out of your price range but if it were me, I�d get a 4440. It�ll outwork either of the 30 series you are thinking of.
John A
12-28-2003 08:11:54
My biggest gripe about ALL the 30 series was that JD did not put enough radiator in front of them to allow you to really work them in hot weather. We had a radiator shop recore ours with larger cores. Just something else for you to think about.
g pop
12-28-2003 07:29:00
depends on how much horse power and weight you need,we;ve had both the 4430 has 540and 1000 the 4630 just 1000.if you can get along with around 125 hp get the 4430,a more all around tractor.
Allen
12-28-2003 04:47:09
we had a 4430 that just turned 10,400 hrs, engine was never touched until now, had a head gasket leaking also found 2 broken head bolts, had head checked and put her back together, we had checked bottom brgs a year ago and they where still within spec, had always used plus-50 JD oil& did oil scans yearly, lots of power, pulled a 5 furrow adjustable plow (most of the time at 22") about the only thing major was a air conditioning up-date, rad & starter.
'51 A
12-27-2003 19:18:08
Yes, if you can find a '77 model 4430 or 4630, then you will have all the updates that JD had for these tractors in the tranny.
John
12-27-2003 18:56:41
Steve:
The 4630 is a beefier tractor than the 4430. They both have the 404 engine ( some will say they are marginal, some will complain), but the 46 has an intercooler and a little more fuel for about 25 more horsepower. The 4430 has 540 and 1000 RPM PTO stub shafts while the 4630 only has the 1000.
John
Hilltopper
12-27-2003 18:03:40
IN 1981 we bought a used 4630. It had signs on the rear that it had been apart. I asked the salesman and he said they had all been up dated. The one we bought was a 1977. It had power shift. These are a light tractor for their size. We ended up putting alcohol in the duals, for it was always spinning pulling a 20' disk. I had been warned this was a no no. In '89 ' the powershift unit went out and it cost about $2500 to get it repaired. They are a good tractor if used correctly.
