J.d.crawler diesel.hard,I mean hard to start
dick
11-17-2002 09:09:00
I just purchased this crawler,the person i got it from told me it was hard to start.I have operator & shop manual ordered.If anyone could tell me what to check or do I would appreciate it. thanks in advance for any help.
Chris
11-17-2002 14:51:35
 Re: j.d.crawler diesel.hard,I mean hard to start in reply to dick, 11-17-2002 09:09:00
does it smoke while running? If it does you could have a low compression problem and the rings arent sealing enough to ignite the diesel. If its not smoking and the comp is good the i would say your having problems getting fuel and thats why the either is working. Its running on either till the fuel gets there. Then when you restart it it still has fuel.
dick
11-17-2002 17:32:18
 Re: Re: j.d.crawler diesel.hard,I mean hard to start in reply to Chris, 11-17-2002 14:51:35
thanks Chris It does smoke when running maybe when i get service manual i can check compression.
dick
11-17-2002 13:01:42
thanks chris for bringing this to my attention.john deere 3 cylinder,2stroke,47 h.p.no glow plugs I have tried starter fluid,it will fire several times ,but fails to run .after running awhile it will start easy no starter fluid. the weather here around 60.thanks again for any help. dick p.s john deere 350 B supposed to be late 70s
Jonathan
11-17-2002 14:40:01
 Re: Re: j.d.crawler diesel.hard,I mean hard to start in reply to dick, 11-17-2002 13:01:42
Hopefully it was a good buy, because hard starting is usually not a strong selling point !!...But anyway...does it smoke white when cranking to initially start it ??? Or is there no smoke when its cranking ???
dick
11-17-2002 17:40:20
 Re: Re: Re: j.d.crawler diesel.hard,I mean hard to start in reply to Jonathan, 11-17-2002 14:40:01
thanks jonathan i hope it was good buy, some white smoke while cranking,
Chris
11-17-2002 09:51:12
what type crawler. then maybe someone can help.
