Difference between a M and MT
Larry Metzgar
11-16-2002 17:42:27
I bought a JD MT back 30 years ago when I first started out farming. It had the traditional narrow frontend. I went to a bone yard the other day and found a wide front off a M. What would keep me from installing this on the MT for vegtable use on our farm. Was there some other difference between the two that I dont see? Could always change it back for resale value. Its been a good tractor but need the wider front .
Thanks,
Larry
Russ Smart
11-21-2002 17:22:30
 Re: Difference between a M and MT in reply to Larry Metzgar, 11-16-2002 17:42:27
You would need the front end for a MTW as the M is a much lower tractor, as Pat stated.
Richard
11-16-2002 20:51:37
Factory wide fronts are available for your MT at Dave Cook, (715)-373-2092. Origonal would be better than a mixed parts tractor.
pat
11-16-2002 18:02:15
Larry,
It just so happens I have a MT with a M wide front. It sets down hill in the front about 3-4 inches, and will not adjust very wide. I use it for pulling and odd jobs around the farm and it works well. I will E-mail some pics to you.
Hope this helps, Pat
