JD 60 rear hub wedges
KB
12-27-2003 15:58:45
I have one that is really worn on the key the question that I am posing is what material is the made from? and can the key be built up with weld? or the last obvious question is this a waste of time? Dad is leaning toward building them up rather than locating a replacement and I am leaning towards replacing it but....
MIKE HANLEY
12-28-2003 16:40:53
 Re: JD 60 rear hub wedges in reply to KB, 12-27-2003 15:58:45
I agree with Mike. Replace it. It MUST BE TITE and fit with zero clearance, or you are not gaining a thing. Recall I said in your post below that if you wear into the axel, thats $350, plus labor. I would like to meet the welder that can do it and then grind it back with a hand grinder for the zero tite claerance. Maybe if it was machined back. But not with a hand grinder. New one from JD is about $100. Used one will cost at least 1/2 maybe 3/4's of that with shipping. Rather a new hub now then a new hub AND an new axel later.
Mike W J
12-28-2003 16:16:03
Look in a salvage yard there has to be a million of them they are the same on a 3010 3020 70 720 620 630 730 etc.
