60 radiator removal
moline
12-27-2003 15:50:56
The IT manual shows removing the steering worm shaft to remove radiator.They dont show a power steering model.I went to the power steering section and they say to remove the steering valve and then the worm shaft housing.I have a good working PS system and dont want it out of adjustment but the radiator core is bad.Can I just remove the 4 bolts from the worm housing and take off the housing and valve without disturbing the valve bolts or adjustments?Also when I uncoupled the steering shaft at the worm gear,I noticed the splines are worn in the worm shaft and on the shaft.Are parts available or dont worry about it as the tractor will not see more than 10 hrs of use a year?Any help would be appreciated.Also there is no timing to worry about on the worm to sector is there??Thanks,Moline
RAY
12-27-2003 19:34:20
 Re: 60 radiator removal in reply to moline, 12-27-2003 15:50:56
I'M SURE YOUR 60 IS SIMILAR TO MY 520, SO BUCK UP AND TAKE THAT WORM GEAR OUT OF THE SIDE OF THE POST. IT'S THE ONLY WAY TO GET THE RADIATOR OUT. ALSO THERE MAY BE A COUPLE OF SMALL SHEET METAL WINGS ON THE BOTTEM ON EACH SIDE TO PREVENT TRASH FROM COMMING UP THE FRAME. THOSE WILL HAVE TO COME OFF. JUST BE THANKFULL YOU DON'T HAVE A WATER PUMP IN THE BOTTEM TANK. I THINK IT TOOK MORE TIME TO PUT THE THING BACK TOGETHER, JUST BECAUSE IT IS HARD TO GET EVERYTHING TO LINE BACK UP. TAKE YOUR TIME.
Stuart
12-28-2003 20:36:22
 Re: Re: 60 radiator removal in reply to RAY, 12-27-2003 19:34:20
No, you dont have to take the PS off. I put a new core in my 60 and I never had to take it off.It will make life a lot easier if you dont touch that worm gear. I spent alot of time adjusting mine, and I didnt even remove it to get to the radiator.
moline
12-27-2003 19:47:31
Ray,thanks for the advice.Unfortunately,I do have a water pump.The manual says to remove it before removing the radiator.The tractor is also an LP model but it looks like the tank is not a problem.The rows of rusty nasty bolts on the rad tanks look like fun.My radiator man said to heat with a torch and take my time.They must be a bugger because I couldnt even talk him into removing the tanks for beer!!LOL Thanks again,Moline
