Operating Temp for a model 50
John Van Valken
11-15-2002 17:49:18
Hello All,
My model 50 came to me without the radiator shutters. Its a 1953 model and so it predates the automobile styled theromstat that controls coolant flow. I just got a used set of shutters that I'm going to install soon but I don't really trust that old rusty mechanical thermostat arrangement. I'm planning on installing a manual control rod where I can be sure the shutters are closed or open at any given time.
My question is, what is the normal operating temperature for the model 50? Running without shutters my 50 won't even reach 140 degrees and requires a pretty rich mixture to run under load. I'm hoping that regulating the temp will allow me to lean things up a bit.
This brings me to another question, how long does it take for a 50 to reach operating temperature? Seems like it's going to take forever to heat up those 7 gallons of coolant!
Thanks,
John
Steve - IN
11-17-2002 10:13:49
 Re: Operating Temp for a model 50 in reply to John Van Valkenburgh, 11-15-2002 17:49:18
2 more cents...
The JD manual sets freezing as the point to turn on the manifold heat; probably assumes a normally balanced mixture and say 50% humidty. In dry cold you won't need it 'til the temp approaches 0.
You'll notice fuel mixture requirements differ by air density from summer to winter. The cold, dense air requires more fuel for the same mixture ratio. Humidity has a similar effect by displacing air with water molecules. What may have been too rich a few weeks ago, might be just right today. If you've ever flown a piston driven bird, you'll remember changing the mixture by the numbers on the EGT gauge temp as the best way to do it, and applying carb heat as temp and dew point get within "20" of one another, with 20/20 being the condition that most requires carb heat. Obviously your 50 isn't going to fall out of the sky - but if you're tuning your mixture like it could; those are the parameters to use.
Mooney 505Lima out...
mike c
11-16-2002 21:48:34
I have a 50 with a thermostat that I bush hog with
in the summer @90+ ambient temp. Under moderate load it probably takes 30-40 minutes to reach 180-190 degres and will stay there under load, but will cool 10-15deg (at least) driving back to the house. That being said, right now it is 50deg outside and it may would take an hour of running around with no load to get it up to 130deg. This engine has about 100hrs since overhaul. It takes some time and work to build up heat in these engines.
Clooney
11-16-2002 05:17:58
John, I have worked on a few early 50's with the shutter system but haven't ever owned one so I will have to compare it to the late B. ~It will take it a while to reach operating temperature & might never if it's cold & the tractor isn't worked. At 20�-30�F it takes my late B over 15 minutes to reach the point that I have to start opening the shutters when under a moderate load, & I have used it most of the morning pulling a trailer or light blade work at 10�-20�F without opening the shutters at all. That is with a thermosiphon cooling system, on your 50 with a water pump you have much more cold water to deal with & the radiator is cooling the coolant all the time, not just when it gets hot enough to get there.
~Even during the summer it takes a while under load before the shutters have to be opened more than a slight amount.
~On the rich carb setting; if you are using the tractor at cold ambient temperatures or light loads you should turn the manifold heat valve to the HOT position, that will put heat on the intake & allow a leaner carb setting with better fuel vaporization. ~These old 2-cylinder Deere's take a long time to warm up when not operated under a load & the more wear on the engine & the lower the compression the longer it takes. ~A good working thermostat will help, & on the shutter systems a good tight sealing proper fitting set of shutters are a must to get the engine temperature up to 170�+.
Steve - IN
11-15-2002 20:56:39
John,
From a 60 owner -- I think if you check, you'll find 50's, 60's, etc. have way more coolant capacity per cu. in. that any car or truck you've worked on. My 60 will run at 180 to 190 all day long when it's over 90 degrees outside.
Guessing you're in a colder ambient temp right now. Put cardboard, or green plastic trash bags or something in front of the screen until it warms up, and until you get your shutters installed.
The running rich while cold under load doesn't sound right. Are you saying you have to keep the choke on? Or, adjust the carb? Normally, a rich mixture runs cool - a lean mixture runs hot. Could indicate other problems.
But.. deal with one variable at a time instead of trying to fix many things at once -- then you don't have so many variables up in the air that you don't know what worked, and what didn't. Try occluding the intake air to get it up past 140 -- maybe 160. If it's 30 to 40 some degrees outside, that may be the best you can do.
Once you get to that temp, and it may take a while, then start worrying about the mixture settings.
Steve
