JD 40 Hydraulic Pump
Chip Fontaine
11-15-2002 10:02:47
Have need for a Hydraulic pump on a JD 40. It is mounted on the front end of the engine. Can anyone suggest a reasonably priced source for one of these?
Henry J
11-16-2002 08:46:30
 Re: JD 40 Hydraulic Pump in reply to Chip Fontaine, 11-15-2002 10:02:47
Chip
I am sure you have trouble shot the problem down to needing a different pump. It is very commoin for those to not be pumping and the pump be totally serviceable. A couple of things that come to mind are air in the system or air leaking into the return line system. Good Luck
Chip Fontaine
11-17-2002 04:55:30
 Re: Re: JD 40 Hydraulic Pump in reply to Henry J, 11-16-2002 08:46:30
Thanks for the info. The pump was working then I got no pressure to the lift system at the rear of the tractor. Also, the pump will put oil into the engine sump.. Seal Leak??
twopop
11-15-2002 17:37:52
I needed one about a month ago,listed it in the classied ads in wanted section.got one
