4010 Diesel Batteries Clooney or John T
Farmer Jack
10-18-2003 17:52:18
I tried starting my 4010 D today, but no oomph in the batteries. popped off the caps and they were really low in water. I added water to both. One charging just fine and the other seems dead. Are 24V systems like tires on cars? One should replace both batteries or can I get by with just one.
Thanks,
Farmer Jack
John T
10-18-2003 21:11:57
 Re: 4010 Diesel Batteries Clooney or John T in reply to Farmer Jack, 10-18-2003 17:52:18
Hi Farmer Jack, I pretty well agree with the rest of gentlemen below. On dual battery charging and startign systems, its best if both batteries are similar in condition, rating and state of charge. Im not sayign it still wont work so long as both batteries are in fairly decent condition, its just that its better if both are near the same.
You might want to take a look at the charging voltage (as you said it was low on acid) across both batteries as overcharging can boil them over and loose acid plus it can be worse on the batteries than undercharging. If its been outgassing and loosing excess water/acid, there may be a voltage regulation problem. I dont have the charge voltage specs, but my guess is it would be around the 26 to 28 volt range. The batteries need to have electrolyte above the plates and no cells should have any gray or milky apprearance. Make sure all cables and connection and grounds are clean and secure.
Best Wishes n God Bless
John T
Bob
10-18-2003 20:13:44
Change them both. Period. The generator charges the 2 batteries in series at 24 volts, and if the other battery is less than perfect, they will not charge equally, leading to one or the other "gasing", and/or giving other problems.
It's tough to spend the money for both at once, but 80 - 90% of the time it's the only way to get good reliable service out of the batteries.
If you replace only one, and it's useful life is reduced by 1/2 because the other battery is not up to par, you have saved nothing, in the long run.
Bob... who has only too many times seen people try to save money in this matter. (And who changes the batteries in his 4020 in pairs every 5 -8 years.)
R Marg
10-18-2003 18:21:19
you can get by with only getting one but it will only give as good as what the older battery has so yes if money is short go with one but it is better to get 2
