Gas caps
tom lucey
11-14-2002 14:00:54
Have a problem w/gas leaking @ gas cap,have replaced them and even filed the top of the neck flat to no avail, any solutions?
Clooney
11-14-2002 15:34:51
 Re: gas caps in reply to tom lucey, 11-14-2002 14:00:54
Tom, what tractor are you having a problem with?
~If you are using a vented cap on a tank the has a remote vent tube they will splash some fuel out of the cap vent due to no baffle at the cap area.
~If it is on a tank that is supposed to have a vented cap then you might be using incorrect caps, defective caps or the neck is actually leaking at the tank. ~I have had a few leakers over the years & stopped the leak by using 2 gaskets under the cap.
