J D H Carb Problem Need Help
Steve
12-27-2003 12:37:36
I cant get my new to me "H" to run properly.The load needle setting doesn't change the way it runs,(with it all the way closed or open 1,2 or 3 turns). The only way I can get it to sound half way ok, is to have the idle setting at 3 1/4 turns out(too many I think).Adjusting the load setting doesn't change this .I have tried to reduce the turns on the idle and open the load but it will not work. So I tried to remove the load nozzel but could not. I gave it to a man who has done lots of these carbs. He said he had to drill it out(first one he ever had to do this with, he always got the others out).He put a new load nozzel in and it still acts the same way.I haven't had a chance to speak with him since. What should I try next?
Clooney
12-27-2003 12:55:17
 Re: J D H Carb Problem Need Help in reply to Steve , 12-27-2003 12:37:36
Steve, you missed a passage in that carb... Send me your E-Mail address & I will send you a carb cleaning diagram of that DLTX 26/46 carb.. I will also send you some data on other things to check... ~When you E-Mail me.. put "H Carb" in the subject line so I can find it in the maze of E-Mails I have in my in-box now...
[email protected]
