Jd b transmission
Charlie Westbro
11-13-2002 20:41:03
I have been working on a 1951 B, after i got it running and started driving it i noticed it has a knock in gears 1,2,4 and reverse. the other gears run perfect. Can anyone tell me what would be causing this and how much trouble it is to replace gears in the transmission if needed.
Clooney
11-14-2002 03:18:41
 Re: jd b transmission in reply to Charlie Westbrook Jr., 11-13-2002 20:41:03
Charlie, given the gears it makes noise in it sounds like your problem is either in or related to the idler gear area. It [could] be bad bearings on the sliding gear shaft & the shaft is just getting supported by the input shaft in the quiet gears but I'm betting idler gear or input shaft to idler gear area. Unfortunately the trans has to come completely apart for the idler gear work.
~You probably should pull the trans top cover & look at the gear teeth & reach in & try to move the idler gear assembly & other shafts to see if you can find a problem.
~If you have been into other 2-cylinder transmissions the B is pretty easy, at least it isn't a Diesel 720 with a pony..
