Deere 435 How rare of a machine is it
Denny Foster
12-27-2003 07:55:03
There was a 435 close by and I let it get away and now I am wondering if I should kick myself and how hard?
Denny
buckeye al
12-30-2003 15:20:25
 Re: Deere 435 How rare of a machine is it in reply to Denny Foster, 12-27-2003 07:55:03
I take my dyno to a local show each fall. Have run several on the dyno. That litle 2-53 really jumps on the load as do most GM's. As you apply the load it's almost like the tractor's watching you. Very very sensitive governors. They make more noise as they jump on the load but the tach barely moves. One went from no load to full load & only rolled off about 30 PTO rpm. Will sit there around 40 HP all day. One was paraded a lot & initially crapped out under 30 but as the blue smoke rolled & soot balls blew out the stack he kept getting stronger minute by minute. After a while the sky cleared, the birds took down their detour signs & both the tractor and the owner were happy. The dyno makes 'em roar and nothing sounds quite like they do, a stout little tractor with a big mouth but he means business!
William Peets
01-16-2004 12:24:30
 Re: Re: Deere 435 How rare of a machine is it in reply to buckeye al, 12-30-2003 15:20:25
Just wondering what rear tires and wheels came stock on 435 tractors. We have 14.9 x 28" and I know of 34" Leger stated his rice 435 had 36". Does anyone know if 36" were stock. My wife and I pull 435's in the antique class and would like to go to a higher tire. 34's that I know of are very narrow and would not work for us. 36" would be excellent but must be a stock item to be able to be used in our club. Can anyone give me some info.
leger
12-28-2003 20:17:14
Rice 435? -- 7.50 front 14.9 X 36 R2 rear, 4 speed. Original from the factory. South Louisiana tractor. It is parked in my shed.
greenbob
12-27-2003 16:59:16
a friend of mine has a 435 and loves it.
Larry
12-27-2003 14:56:23
I've had a 435 for probably 10 years and love it. I use it for plow days and will just about run away with 2-14's. It has the swept back front axle and heavy duty fenders. My only concern is if it is below 45 degrees it needs to be plugged in but that is easy. It is a great tractor!
Jack B
12-27-2003 14:02:03
I have a 435 Ijust bought about two weeks ago and my tachometer is missing if any of you guys know were one might be please let me know.I like mine good so far, I am going to restore it, a retired john deere mechanic is going to do most of the work so may be it will turn out good.PS also need a battery tray.Thanks Jack B.
buickanddeere
12-27-2003 19:44:31
 Re: Re: Deere 435 How rare of a machine is it in reply to Jack B, 12-27-2003 14:02:03
There never was a tach, just an electric hourmeter. An AC Delco mechanical tach does drop right into the dash and drive of the cam. 49% of 435's went through the Atlanta Branch. Some have survived in the deep warm south. Northern 435's have mostly been blown with ether, rear ends worn out by farmers thinking they had a "diesel 630". They would ballast it way past the 4500lb max to over 6000+lbs and work the guts out of it lugging in 1st gear. Or the row-crop utility cast front axle "C" section was busted by having a tow chain wrapped around it. The upper front hood piece above the rad grill either gets broken or "lost". Good luck, it's made out of unatainium. I had two 435's, regret selling one and love the other screaming little so and so. A very female tractor, good when it's good and bad when it's bad. A "N" series engine rebuild, high torque starter windings, a huge battery, charge regulator set to 14.2V, block heater and synthetic lube in the trans solves all problems.
Stan - Florida
12-27-2003 09:39:12
There were 4626 of them made, and the real rarity would depend on the options. For example, there were only 30 with 1,000 RPM PTOs, 118 with 34" rear tires, 245 with four speed tranny, 619 with power steering, 998 with swept-back axle and 1,734 with spin-out wheels.
It's been said that they sounded like a chainsaw on steroids.
Stan
CPeter
12-27-2003 10:26:34
 Re: Re: Deere 435 How rare of a machine is it in reply to Stan - Florida, 12-27-2003 09:39:12
That sounds like quotes from JR Hobbs. Just finished reading the book "The Little Giants" and the remark about a "chainsaw on steriods" was used in the book.
JR also goes on to say that because the engine is a 2-53 Detroit by GM that parts for it are readily available and the rest of the machine is made up from the Deere parts bin. Would be kind of neat to have.
CPeter
Stan - Florida
12-27-2003 12:35:22
 Re: Re: Re: Deere 435 How rare of a machine is in reply to CPeter, 12-27-2003 10:26:34
You're ablolutely right about the quote - it's from a Green Mag article by JR.
Years ago a neighbor told me of an old John Deere out in the weeds at a friend's house. Just for grins I went out to see it. It was a 435, which I had not even heard about until then. In addition, I would not have even drug it out of the weeds if they'd paid me to. I told a collector friend of mine about it and took him out to see it. He bought it on the spot, and turned around and sold it to a collector up in the Midwest sight unseen. They're a neat little beast, alright.
A friend of mine in Iowa told me that a 435 was his first tractor - he didn't like it much, he told me. Not sure why, but the noise might have been a factor.
Stan
CPeter
12-27-2003 14:32:11
 Re: Re: Re: Re: Deere 435 How rare of a machine in reply to Stan - Florida, 12-27-2003 12:35:22
The Detroit is a unique beast. I am a volunteer fireman and we have a '79 Louisville Ford L9000 with a 6V92TA turned up to fire truck specs, i.e. 2,600 rpm top speed. With almost no muffler on it, I can hear them pull out of the station from here at home, which is a mile away. One night, at a big fire I had it wound pretty near tight and the chief from the next town came over and wanted to know what the awful sound was. Well I listened and listened and it sounded OK to me and then, realizing that his truck had a 300 Cummins in it figured out that it was just the "Detroit" sound. I love it.
CPeter
Denny Foster
12-27-2003 16:16:56
 Re: Re: Re: Re: Re: Deere 435 How rare of a mach in reply to CPeter, 12-27-2003 14:32:11
running tractor could have been bought most likely for $1000 Or less?
Denny
buickanddeere
12-27-2003 19:46:30
 Re: Re: Re: Re: Re: Re: Deere 435 How rare of a in reply to Denny Foster, 12-27-2003 16:16:56
A deal. A 435 is worth about the same as a 320 in similar condition.
