A good leaf collection system for a lawn mower?
Ken
11-11-2002 18:53:46
Does anyone know of a good leaf collection system to go with a riding lawn mower?
Jimbob
11-12-2002 06:20:56
 Re: A good leaf collection system for a lawn mower? in reply to Ken, 11-11-2002 18:53:46
I have an MC 519 behind my 345. It is an intregal part of the tractor as the trailer is rigidly connected to the tractor frame. No external motor required. Picks up everything ezcept wet grass. ALWAYS, ALWAYS run any collection system at full throttle as they were designed to operate that way to avoid clogs.
Andy
11-12-2002 04:14:49
I have a Trac Vac system on my JD 335 that was purchased from the John Deere dealer. It is a 20 bushel pull-behind system. The engine mounts to a bracket on the tractor frame, so it rides along with the tractor. I have used the AgriFab units and I have found that while they are a self-contained unit, they do not manuever as well because they have a longer trailer tongue to accommodate the engine. The Trac Vac uses a standard size utility cart with some sides on it and with the engine being mounted to the tractor, it will follow right behind your tractor and it will not graze trees, houses or anything else. I really like it and it seems to have enough power to suck up even semi-wet leaves without clogging. Might try looking up both on the web and seeing which one better fits your needs...
Henry J
11-12-2002 04:00:59
Ken
I lived on a property that was full of mature oak trees. Truck fulls of leaves. I bought one of the two wheel trailers with a 5 hp motor running the vacuum blower on it made by AGRIFAB. They come with a discharge chute attachment that can be cut to fit most deck discharges. It worked great when the leaves were dry. Using this system the blades of the mower also helped grind and get more leaf volume in the trailer. Don't expect the pile to compost down by itself quickly though. It seemed like it was going to stay dry inside forever. On a super dry day, however, you will be trying to stay away from being downwind - it is dusty and the dry leaf dust choked me up.
Steve - IN
11-11-2002 20:12:30
Ken,
Not many details to go with there.
I'll assume you have a JD lawn tractor. I've got one too and stuck a JD MC519 system on it. An impeller fits over the discharge chute of the cutting deck, and is driven by a belt from a blade spindle -- blows stuff back up a big plastic pipe to a little cart on the back. Holds about 20 bushels. Works well when the grass or the leaves are DRY! When they're even a little damp, you'll spend a lot of time cussing and cleaning out the chutes. It's easy to use and dump, so the women use it! Ours is 4 wheel steer 425 JD, so they wack the cart into trees, the house, fences, even caught a car with it once.
If you don't have a JD, and the maker of the tractor doesn't offer anything; you're in to one of the after market boxes with its own engine to power the impeller chute. I'd imagine snugging it up to the cutting deck discharge area would be a problem. Failing all that, one of the pull behind ground driven brush type devices are relativly cheap and work with anything.
They all seem to be a lot more tempermental than a good hay baler (or maybe I have a lot more respect for balers than the leaf catchers), so wait 'til all the material you're collecting is nicely dried.
Steve
