How does the seals on the pto shaft keep power trol from getting into the gearbox
charlie
11-11-2002 15:59:11
I took the PTO oil pump apart because I want to replace the oil seals so that I do not leak power trol oil into my gearbox. My question is how does the oil seals actually work to seal this oil?
The reason I ask this is because I took all the seals off the PTO shaft and there seems to be one bearing at the very back of the housing and it seems that it is pressed into the back of the housing where the pto shaft goes through this bearing into the gearbox. The pto shaft fits very loosely and I can't see how it will stop oil from flowing into the grearbox or from the gearbox into the cavity behind the pump assembly.
When I put on the new seals there is a spring that presses these seals into a cup, and then presses this whole group against the bearing in the back of the cavity behind the pump. My question is , does the spring cause pressure against the seal so that oil will not flow? Is it correct that gear oil fill the cavity behind the pump and the seals only keep oil from leaking out of the pump into ythis cavity?
Clooney
11-11-2002 16:43:50
 Re: How does the seals on the pto shaft keep power trol from getting into the gearbox in reply to charlie, 11-11-2002 15:59:11
Charlie, the seal on the PTO pump works like a water pump seal or old style Delco A/C compressor seal. The spring pushes a packing type material into the space between the shaft & cup & the cup seals on a bearing type cone that rides on the housing. The higher the pump pressure the better it seals. There is gear oil on the front side of the rear housing & the pump [power-trol oil] is on the back with the seal between them.
ron in MN
11-11-2002 19:03:18
 Re: Re: How does the seals on the pto shaft keep power trol from getting into the gearbox in reply to Clooney, 11-11-2002 16:43:50
Which tractors are you guys talking about? I wasn't aware that PTO shaft seals have anything to do with Powr-trol oil. On my 50 the two never meet.
G-MAN
11-12-2002 10:20:38
 Re: Re: Re: How does the seals on the pto shaft keep power trol from getting into the gearbox in reply to ron in MN, 11-11-2002 19:03:18
Ron, on the older power-trol and power-lift systems, the pump is driven by the PTO shaft, and the gears are located in a housing directly in front of where the PTO shaft comes out of the housing. The PTO shaft actually runs through the drive gear, and there is another gear of equal size that makes up the rest of the gear pump. There is power-trol oil in the gear housing and gear lube in the rear end, so if the seal leaks, you can transfer power-trol oil into the rear end. The power-trol pump on your "50" is driven off the end of the engine governor, so this situation isn't going to apply to your tractor.
