JD Model MT Rocker Arms
Ron Mason
11-11-2002 14:57:05
My rocker arm bores and shaft are pretty well worn. I can take care of the shaft but can the rockers be bored oversized and bushed? Are standard oversize bushings available?
Clooney
11-11-2002 15:20:43
 Re: JD Model MT Rocker Arms in reply to Ron Mason, 11-11-2002 14:57:05
Ron, nothing from Deere on the rocker arm bushings. The arms could probably be machined out & standard bushings installed but that would probably cost way more than good use ones would cost. ~I'll bet if you make a few phone calls you could find & good used shaft & rocker arms as an assembly.
Ron Mason
11-11-2002 15:36:18
 Re: Re: JD Model MT Rocker Arms in reply to Clooney, 11-11-2002 15:20:43
Thanks.I can get new ones from JD. There about $75 a piece for the arms and shaft. That's about $375 Total for a couple of parts.Too much for me. I want to stay away from used parts for this right now. I can get the shaft metal sprayed and machined for free, but a was hopeing to bush and ream the rockers on my drill press some how.
