720D Fuel system
Bigger Iron
11-11-2002 08:50:08
I would like to upgrade the fuel system on my 720D. Are the injectors and pumps different on a late black dash 720? If so, need JD part numbers.
Thank you.
Clooney
11-11-2002 14:33:08
 Re: 720D Fuel system in reply to Bigger Iron, 11-11-2002 08:50:08
Bigger Iron, yes the injectors, pumps, pump bracket, transfer pump + many other parts are different.
~You really need a parts book [& a wheelbarrow full of cash] to even consider that up grade.
~Probably your best bet would be to call Albert at Renaissance Tractor [1-800-7840026] he is the diesel expert & can probably tell you what would be required & what parts give you the best bang for the buck.
