JD 2510 Diesel Engine Oil Pressure
Leland Oeser
12-27-2003 07:24:16
I have a JD 2510 Diesel. The engine oil pressure light comes on at idle after the engine is hot.
What is the correct oil pressure? I want to check it with a gauge. Will it help to add shim washers to the relief valve at the timing cover?
Thanks,
Leland
jdtractortech
12-28-2003 08:31:15
 Re: JD 2510 Diesel Engine Oil Pressure in reply to Leland Oeser, 12-27-2003 07:24:16
Leland, If you pull the injection pump out and remove the shaft you will probably find the umbrela seal is damaged. I would have a qualifies person do this if you are not familier with pulling the pump. Its possible it may be coming from the transfer pump. Make sure you change the oil AND the filter or more serious damage may result. As far as shim washer...there is a problem somewhere that needs to be resolved first. If I can help you more send a messege back.
Dave
Leland Oeser
12-28-2003 08:47:45
 Re: Re: JD 2510 Diesel Engine Oil Pressure in reply to jdtractortech, 12-28-2003 08:31:15
Thanks, Dave
I have changed the oil & filter. I checked the oil pressure with a mechanical gauge. It was OK.
I have pulled Injection pumps before to have them rebuilt. For now I will keep a closely monitor oil level and pressure.
I will wait and pull pump this next Spring if I can.
Thanks,
Leland
Leland Oeser
12-27-2003 16:46:42
I found the reason for low oil pressure. The engine oil was diluted with diesel fuel.
There is no visible diesel fuel leaking from the weep hole on the fuel transfer pump.
Where is the diesel fuel coming from?
Is it the shaft seals on the drive shaft for the Injection pump?
Thanks,
Leland
