Hello all, I finally got my old model 50 (gas) running again this weekend. Had a problem with the carb that turned out to be a plugged passage to the load screw. The first thing I've noticed is that it seems to be running quite rich. The engine sounds okay but you can see dark exhaust and smell it. I've leaned out the two idle screws and have the load screw set to about 1 1/2 turns. Seems that if I run the load screw leaner that it fumbles when the engine takes a load. The radiator shutters are missing (I've got some on the way) and the temp never even reached 140. Do you suppose that I could lean it out a bit if it ran closer to 160? There is LOTS of transmission noise in all gears whenever the clutch is engaged. I noticed the transmission oil looked a little milky. Certainly due for a change. I'm wondering if the power-trol oil leaked into the transmission? What kind of oil are people using in the power-trol? I thought about using hydraulic oil. Any recommendations for transmission oil for a noisy (probably worn) transmission? I ran a compression test on the engine. 80 lbs on the left cylinder and around 100 lbs on the right side. Sound about right? I'm hearing a little valve tap on the left side so I'm going to try adjusting the valves to see if I get the left cylinder up closer to the right. What are people using to measure engine speed on these two cylinders? I'm not looking for a permanent tach, just a test unit. I don't think the fast idle is reaching 1200. I've also noticed that the slow idle is pretty quick. Sounds like it runs about 1000 rpm. I've got the idle screw all the way out. I noticed that the throttle plate on one cylinder did not quite close all the way. Where are people getting clutch parts? The dealer? My clutch has a LOT of play before it engages and a LOT of play before it "snaps out". I'm guessing I'll need to replace the clutch fork and other hardware. Thanks for your advice! John
