B carb rebuild
Scott
12-27-2003 06:43:45
Tractor has been sitting for a year, I have carb off now what is recommended? Also who sells reasonably priced rebuild kit?
Clooney
12-27-2003 10:23:14
 Re: B carb rebuild in reply to Scott, 12-27-2003 06:43:45
Scott, what condition is the carb in? Is it real rusted up, or just gummy inside? Or is it in real good shape but just needs a cleaning.. At the very least you need to pull the carb apart & remove the passage brass plugs & pull the load nozzle out & clean the nozzle & clean the main passages out. If it's real rusted up inside you will have to do more [lots more]....
~Does the throttle shaft & choke move smoothly & fully?
~Are the throttle shaft & bushings sloppy?
~Is the throttle plate worn on the ends?
~Any of the casting(s) broken?
~Let us know what you are starting with & we'll make a recommendation on the proper approach to that DLTX carb..
~I don't know about " reasonably priced rebuild kit" but you can get quality ones at a fair price from Robert's Carburetor Repair [712-262 5311].. Or see web site link below...
[email protected]
