How to turn up a 3010
rusty
11-08-2002 08:25:37
I have a 3010d I have heard a lot about turning up the hp. How do you do that on this model .
willie
11-08-2002 18:38:24
 Re: how to turn up a 3010 in reply to rusty, 11-08-2002 08:25:37
Make sure that your pump has an advance on it, if you have never worked on these pumps then take it off and have someone take out the shim, if there is any, behind the smoke screw. Yes it may smoke a little bit but at least you know you are getting all of the power out of it that you can. I doubt that you are going to hurt a good broke in engine much. I wouldnt turn the rpms up though.
G-MAN
11-08-2002 09:13:06
How much more horsepower do you think you need? I would start with a good tune-up. Adjust valves, clean the air filter, replace the fuel filter, check compression, check nozzles and replace if necessary, and so on. Those four-cylinder naturally-aspirated engines aren't going to respond a bunch to increasing the fuel delivery, especially if the rest of the fuel and intake system isn't up to snuff. More than likely, you're just going to end up overfueling the engine, which will lead to excessive smoke, higher fuel consumption, and possible fuel dilution of the oil and possibly engine damage. If the pump is worn out, turning it up won't help either. Black smoke may look cool and many guys think it's due to more power, but all it is is unburned and wasted fuel going out the pipe.
