SWAYBLOCK SPACERS
John in Md.
11-08-2002 06:03:43
I just went out to put swayblocks back on my 530 and can't find the spacers.Anybody know the length so I can cut new ones? Thanks,John.
Clooney
11-08-2002 06:18:26
 Re: SWAYBLOCK SPACERS in reply to John in Md. , 11-08-2002 06:03:43
John, due to wear on the lift arms, ball sockets & different length implement pins the production spacers will probably be off a little anyway. I usually use 1/4" thick washers & add or subtract to get the correct spacing. Once the spacing is obtained you can either just leave the washers if it's a working tractor or make spacers the height of the washer stack if a show tractor. On my 520 I have both spacers & washers with extra washers under the nut so I can very the spacing for different implements & when using my back blade I use no L/H spacers & space all on the right to off-set the blade farther outside the rear wheel foot print. ~I do have the correct parts on another tractor so if you absolutly need the correct height let me know & when I get a chance I will try to work my way to the back of my storage barn & try to measure them for you.
