How to get 1010 gas tank off? Steering needs work
Dave
11-07-2002 18:23:48
There is a coupler in the steering shaft of my 61 1010 that keeps coming apart if the steering wheel gets pulled back on (yes I drive it keeping pressure on the wheel :)) but I would like to fix the coupler which is between the steering shaft and a short shaft to the PS pump. The problem is the steering shaft goes through the bottom of the gas tank. How do I get to the coupler? I cant just unbolt the tank because of the shaft. Machine has PS.
Leon R
11-07-2002 20:32:31
 Re: how to get 1010 gas tank off? Steering needs work in reply to Dave, 11-07-2002 18:23:48
Dave, to remove the steering shaft on tractors equipped with power steering on tractors with serial numbers up to 48584 you drive out the pin attaching the coupling to the power steering valve. On tractors with serial numbers 48585 and up you remove the snap ring from the coupling and remove both pins. Then you remove the cap screw in the rear coupling joining steering shaft and universal joint. slide the coupling rearward on universal joint to free the shaft. Then slide steering shaft rearward and remove coupling from front of steering shaft. Then you disconnect the tank and lift it and the shaft out.
Have fun!!!!
