How do you attach JD front mount snow plow
charles
11-07-2002 17:43:37
I just bought a front mount cable operated snow plow for a JB B and I believe that I have all the parts to attach it but I would like to see a picture of a tractor with this type of plow attached to get an idea how it is suppose to look. Can anyone send me a foto or un diagram?
I got only found one set of pullies that mount on the front,,,are there other pullies that mount on the rear axles also?
The blade on this plow is 7 foot,,,does a JD B have enough power to plow with this blade?
Rich
11-08-2002 06:21:04
 Re: How do you attach JD front mount snow plow in reply to charles, 11-07-2002 17:43:37
I have one I mount on a 1950 B and it handles it with ease in very hilly conditions. I do have cast wheels, fluid and chains. There are two arms which mount on your rockshaft which have cables which run under the axels up over the pulleys mounted on the front and down to the plow blade for raising it. The scraper blade for the bottom is no longer available from Deere but any blacksmith can make one.
Bill
11-08-2002 04:18:47
I bought my father a manual for the ABG90 plow on Ebay earlier this year. If you can't figure it out let me know and I could scan a picture for you or get you the book number and you can order one from JD.
al
11-07-2002 18:51:22
Charles, sorry I don't have a picture but I remember that the cables go under the rear axles and the lift arms from the rockshaft are turned down to pull the cables so there are now pulleys on the rear.
don cassese
11-07-2002 18:05:25
I have a b and need just this sort of thing. where did you find it and how much etc and did you know if they had another one. i would appreciate your help
