JD 4010 Diesel
Kevin
11-07-2002 15:54:53
I recently bought a 1963 JD 4010 diesel. The engine was overhauled a few years ago, and has about 600 hours on it. The engine runs great, except when it warms up, and is under a slight work load, the engine rpm jumps about 100 rpm, then settles back down. It will do this for about a half hour, then starts to run a little rough, as though it's only running on five cylinders or so. I should add that this tractor was stored in a shed for about a year, and was not used. Fuel stabilizer was added, and I have added new fuel since I bought it. It has a modern cartridge style fuel filter on it. Wondering if this should be changed, or is there something else I should be looking at?
Don Myers
11-08-2002 08:21:44
 Re: JD 4010 Diesel in reply to Kevin, 11-07-2002 15:54:53
SOUNDS LIKE THE GOVERNER WEIGHT RETAINER RING HAS BROKEN AND THAT LETS THE GOVERNER FLOP AND MAKES THE ENGINE RUN ERATIC. REMOVE THE INJ PUMP AND HAVE IT REBUILT. DON
Ty
11-08-2002 06:07:45
I had similar probs on a 4020 on time. Did the filter and the pump. Filter is the glass cart. Still ran like sheet. Had the inj. pump rebuilt. Works FANTASTIC now but pissed away $1,000.
