G-MAN
11-07-2002 17:41:35
Re: Deere 4440 in reply to Aggie, 11-07-2002 14:58:14
4440s are excellent tractors - a good step and possibly two or three above the 4430. Better engines (6466 compared to the 6404), good transmissions and rear ends, and just a rock solid tractor all the way around, providing they've been properly maintained. A 4440 certainly isn't going to have any problems with a 535 baler, if that's what you're referring to when you mention a roller, but you're not going to be way overpowering it either. 4440s are rated at around 145 hp, although most will turn in the neighborhood of 160, even at stock fuel settings. I've seen one turn 260 on the dyno, but I wouldn't recommend doing that, unless you are fond of replacing head gaskets. They make pretty decent loader tractors, especially with the powershift transmission. The quad-range is also an excellent transmission, and the perma-clutch is nigh onto indestructible when properly used and maintained. I would look at tire condition, condition of the cab and upholstery (if it's a Sound-Gard tractor). Check the operation of the hydraulics, transmission, steering and so forth. Look for excessive play at the tie rod ends, spindles and bushings, axle pivot pins and bushings. Those items take a beating if the tractor was used with a loader. Check the fluid levels and conditions, and get service records if possible. I would take along someone familiar with 40 series tractors, were I inexperienced with them and looking to buy. Prices are going to vary due to age, hours and so forth. The hours may not tell you much. I've seen tractors with 4,000 hours that were absolutely shot, and some with 9,000 that were in great shape. That all depends on the previous owner(s). In these parts, you'd probably be looking at spending in the $14,000 range for an decent one. Maybe up to $18,000 or more for a real cream puff, and around $12,000 for one thats a little rough. I work on quite a few of these tractors, so email me if you have any specific questions. I'll be glad to help you all I can.
