B muffler unside down
John
11-06-2002 16:26:17
I have a 41 handstart B that I very much enjoy. I have a home-made 3 point hitch on it so I run a finishing mower and back blade, nothing that needs it to work hi-performance. It needed a new muffler, so I bought a cheapie one at TSC. If I put it on rightside up, it doesn't fit. If I put it upside down, it fits perfectly. I ran it that way all summer and it seems to be ok. I got to thinking though, maybe I should ask you guys. Do you think this would cause too much back pressure? It starts and runs nice, and is nice and quiet too.
Ol John T Nordhoff
11-06-2002 19:09:49
 Re: B muffler unside down in reply to John, 11-06-2002 16:26:17
John, to quote an oft heard line, if it aint broke dont fix it, since you say it runs well. I suspect its a simple open center with slots to the outer core design, in which case the direction of flow doesnt make much difference. Even if it were a closed loop where the gases go out of one chamber and into another separate one, I doubt if there would be excess restriction to the point it would hurt you much even if ran in reverse. Good Luck, Ol John T Nordhoff in Indiana
Clooney
11-06-2002 17:09:42
John, that would depend on the design of the muffler, if just a basic louvered design with the center necked down it probably doesn't matter. [can you look through it?] ~If a center baffle plate(s) type with slotted rings or spaced plates it will probably change the back pressure. [you won't be able to see through that one].
John
11-06-2002 20:13:24
 Re: Re: B muffler unside down in reply to Clooney, 11-06-2002 17:09:42
John/Clooney,
It is the simple open center design with the holes down the center. Thank you so much for your answers. Your friend John in North Dakota
