Clooney i need a little help on 39b
Chris
11-05-2002 14:50:29
Clooney got my 39b home and to my surprise it wont come out of low range to go into high. Where do i start.
KrisA
11-06-2002 07:24:04
 Re: Clooney i need a little help on 39b in reply to Chris, 11-05-2002 14:50:29
Chris, I have the same problem with my '41 B. First of all follow Clooney's advice. If that doesn't work then pull the cover. I found that two of my shifters are rusted SOLID to the shaft. In the process of getting them loosened up as we speak. Good luck. If you do need a different shaft or shifters you can get used for little cost I found. Good luck!
KrisA NC
Clooney
11-05-2002 15:16:36
Chris, start by making sure the trans isn't in reverse. ~If it's below freezing where you are wait untill it warms up to above freezing & if it works then change the trans gear oil.
~Try lifting the lever while trying to move it.
~If either one of the above don't apply then you will probably have to pull the trans cover & take a look...
