John Deere H oil pressure
JRH
11-04-2002 17:53:24
On my '39 H the oil presure ranges between M and above H depending how fast it's running. Could this be caused by a defective gage or the valve in the oil pump not working properly? Thanks Much for the input, John
Clooney
11-04-2002 18:20:10
 Re: John Deere H oil pressure in reply to JRH, 11-04-2002 17:53:24
John, the oil pressure on your "H" should be between M & H with the engine hot [not just idle around hot but working hot] & at fast idle. It will very with RPM & will be a fair amount higher when cold. The viscosity of oil used will also effect the pressure.
~It should be checked with a KNOWN accurate pressure gage & set to 10-15 PSI hot at fast idle.
~If it is too high when hot you can try adjusting the pressure regulator on the oil pump.....
