Hard starting b
peter
11-03-2002 17:16:41
b wont start right up when it starts runs okay, sometimes govenor sticks the throttle at idle so i have to move it manually toget throttle to miove tractor sat outside for 20 years do i need to take gov. apart or is this common?
Clooney
11-03-2002 17:58:25
 Re: hard starting b in reply to peter, 11-03-2002 17:16:41
Peter, that depends on where the resistance is. If it is external then just lube or free up that point. If internal to the governor you can try running it for a while to see if it frees itself up, but if it won't you will have to go into the governor.
~Usually if rust has caused the governor to stick it is the sliding spool for the fork & the bearings in the governor are probably also bad.
