Heli-coil or replace?
Frank M.
11-03-2002 09:20:44
One of the rear hubs on my 39 H has the threads stripped on 3 of the lug bolt holes. Has anyone had any sucess repairing these, or should I start searching for a replacement?
Thanks for any advice or opinions.
Frank M.
Frank M.
11-05-2002 04:02:31
 Re: Heli-coil or replace? in reply to Frank M., 11-03-2002 09:20:44
Thanks for the replies. I'll take it to a machine shop.
Later
Frank M.
SamH
11-03-2002 19:19:17
Heli-coils are plenty strong for the job, but to install them, you need a tap drill, tap, and inserting tool. You also need some way to make sure the heli-coil goes straight into the hub and is in the same location as the original hole. Unless you have the above covered, I suggest you have the job done at a machine shop.
JRH
11-03-2002 17:22:48
The heli-coils are stronger then the threads they replace. I wish I could find some 1/4 - 40 heli-coils for the idle needle threads in my H carb.
Donny-B
11-03-2002 11:39:32
I am a machinist by trade with 25+ years experience and would have no problem using threaded inserts. They have a rockwell "C" hardness of 43-50 with a tensile strength of 200,000 psi. when installed properly.
