4020 (Gas) Generator light comes on when i use the headlights on
Steven M
11-02-2002 15:36:21
When i use the headlights or the blower in the cab, the Gen light comes on. It's not bright, just dim. When i speed the engine up it gets brighter. Not real bright like it is when the engine is not running and the key is on. I tested the generator and regulator. I get 15.5 volts at the gen, and 14.5 at the reg. with the lights or blower on it's around 14 volts at the reg.
I put the cab on the tractor this summer. I'm not sure if i had this problen before or not. I have not had a dead battery.
I had this tractor for 26 years. I know the gen and reg have not been replaced.
Jim B
11-03-2002 04:38:53
 Re: 4020 (Gas) Generator light comes on when i use the headlights on in reply to Steven M, 11-02-2002 15:36:21
Stevan,check your gen. belt,it may need tightening or it could be bottoming out in pulley which will let it slip under increased load and engine speed.Jim B
