Add Hydraulic/rocker arms to '44 JD B?
Lowell J Schaue
11-02-2002 04:04:23
I just purchased a 1944 JD model B without any hydraulic system (bareback) and would like to add rocker arms etc so I can use my ABG 90 blade. Can this be done and how do I go about doing it? THANKS from LOGO
Clooney
11-02-2002 04:21:06
 Re: Add Hydraulic/rocker arms to '44 JD B? in reply to Lowell J Schauer, 11-02-2002 04:04:23
Lowell, yes it can be done. Depending on if you have a PTO, all you need is the rear housing [complete with rockshaft]& valve from a donor tractor. If it doesn't have PTO parts in it then it becomes a much harder conversion as all the PTO parts will have to be added, or possibly a live P/T pump & block-off plate, [harder conversion but will operate more like a modern live system]. ~Your best bet is to get a parts book & study it for the differences, then call around for the complete rear power-trol housing & valve including the lever.
