JD A Breakdown
Blake
10-30-2002 19:29:42
I am 16 and starting my first restoration, I have a very Original 52 A that I am wondering how far to strip down before cleaning, sandblasting, etc. I currently have the hood-gas tank, generator, carb. and gov. linkages, battery box, flywheel cover, shutters and linkages. One thing I am curious if I should remove the radiator and powr-trol, because neither of them leak, also is it necessary to take off the flywheel, clutch, distributor, govenor, and other things such as these. I am going to restore the brakes, steering, and possibly replace some clutch parts. I am not ready for paint but am just curious so for when I am. Thanks, Blake Also, I don't know much about tuning an engine up real well, but I was wondering the trick to making the tractors idle low, such as people are always talking about. Thanks
G-MAN
10-31-2002 10:43:13
 Re: JD A Breakdown in reply to Blake, 10-30-2002 19:29:42
I would not even consider sandblasting the complete tractor unless you intend to disassemble it completely after. No matter how well you plug off the various holes and mask the tractor, that sand will get in everywhere you don't want it. It will get past seals, gaskets, and everywhere else, and you will never get it all back out without complete disassembly. I cringe every time I read a restoration story where the restorer says something like "I rebuilt the engine and replaced the seals and gaskets in the tranmission. Then we sandblasted the tractor and painted it". Sandblasting works great on big cast iron components, but in the wrong hands it can ruin items like sheet metal in a heartbeat. As far as cleaning before painting, excellent results can be achieved with degreasers, scrapers, power-washers, wire brushes, and good old fashioned elbow grease. Like Bob posted, how far you want to take it down is going to depend on your ability, tools, your work area, budget and how much time you want to devote to the project. I am currently in the middle of a bare main case restoration of my '48 "G", and I can tell you that it has been way more work and money so far than I had anticipated it would be. It can also be hard to get up the ambition to work on it, when I've been working all week on other people's green tractors. This one is my dream tractor, so the time and money will be worth it, but I don't know that I'll ever take one this far again - unless someone is paying me to do it, lol.
Good luck with the "A" and whatever you decide to do with it.
Bob K
10-31-2002 05:06:25
Blake, I've found that each person has their own level of expectation when it comes to restoration. It depends on how much of a perfectionist you are and how much trouble (and expense) you want to go to.
If you have the sheet metal parts removed and the tractor is more dirty than rusty, I would:
1. leave the radiator and powr-trol alone, especially if they work and don't leak.
2. Remove the flywheel - easy to do, but make sure you put it back on with the timing marks aligned. Also tighten the clamping bolts very tight.
3. Leave the governor and clutch on if they are working okay and don't leak. (You'd have to hand make a new governor case gasket as Deere doesn't supply the governor-to-crankcase gasket anymore.)
4. Remove the distributor as it is sensitive to dirt and moisture from the cleaning processes on the rest of the tractor.
5. Scrape, clean and wire brush everything else on the tractor. 6. Get the mechanical stuff fixed before you paint.
Post back when you need more help. I've gotten tons of useful advice on this forum from people who have gone before me. Take advantage of us!
snowmantn
10-31-2002 22:01:59
 Re: Re: JD A Breakdown in reply to Bob K, 10-31-2002 05:06:25
Hi Bob K, I just reinstalled the governor on my '51 A and I got a gasket for governor-crankcase from my dealer. Hope I didn't get the last one! Someone said the retainers for rear axles are also unavailible but I ordered everything including new felt and oil seals on daily order. The only catch was the outer retainers for the felt washer but there are a couple places where these are in stock.
snowmantn
