Bob
10-30-2002 05:57:42
Still working on my 3 year effort to get the JD A running. Ever since I first tried starting it up after rebuild, it ran rough with little power. Timing is good, plugs new, condenser & points new (and properly set), new coil, carb cleaned, all passages behind brass screws thoroughly reamed out, float level good, throttle shaft checked for air leakage, manifold checked for leakage and inspected for cracks, tried two different gaskets on carb, tried various adjustments on load and idle (makes a difference, but doesn't solve problem). Since I had the carb off, it not only runs rough, but has to have the choke full shut to run at all, which I'd think indicates an air leak, but I sure can't find it. Recleaned carb passages, checked gas flow at carb connection. Finally noticed backflow out of carb, checked rocker adjustment and found #1 intake too tight. Checked compression: none in #1, so it must have been running on 1 cyl. Adjusted rocker, got good, equal compression in both cyls. Started her up, she ran great ... for about two minutes, then coughed, sputtered, and acted just like before. Probably have tried other stuff that I've forgot to mention ... for example, that I've drained and replaced the fuel, and that spark is good, blue, and will jump a quarter inch. BTW, if I crank her over with full choke, plenty of fuel comes out the petcocks, so I know I'm getting gas to the cyls. Any thoughts on what to try next? Got fuel, got spark, got compression. What am I missing?
