2510 gas running bad
dins1
10-29-2002 22:23:51
my 2310 will not run unless the choke is half way on. I rebuilt the fuel pump. the fuel pump has a sediment bulb on it and will not fill up. is this normal? put a carb kit in and that did not help with the half on choke either. Where is the bleeder screw is for the steering column?
Chad Riddle
10-29-2002 22:36:07
 Re: 2510 gas running bad in reply to dins1, 10-29-2002 22:23:51
Did you change the fuel filter? check for water in your gas? ...or may have a giant bug in your gas tank.
Gary in TX
10-30-2002 12:22:00
 Re: Re: 2510 gas running bad in reply to Chad Riddle, 10-29-2002 22:36:07
I would have to agree, check the filters, fuel line and if possible flush out the tank. I have a 3020 diesel that I had similar problems with that it would run fine idling but when I had the rpm's up it would run the filters out of fuel, turned out to be the inline filter I had in it between the fuel pump and the tank. Felt pretty stupid for not checkingit first but now I know, its all a learning experience.
