John Deere 140 Kohler engine
Gene Baratto
10-29-2002 14:02:40
I am rebuilding a 14 horse Kohler K321AS for my John Deere 140. The fly wheel is secured on the crank with a bolt,which I lost. The parts manual at my John Deere dealer shows the fly wheel secured to the crank with a nut on a threaded shaft. Obviously, there was a change made somewhere along the line. My problem is that I cannot find a bolt to fit and my dealer is not getting an answer for me. I assume the bolt is a special make. Can anyone tell me what knid of bolt is used for this crank?
Thanks
Donny-B
10-29-2002 19:19:42
 Re: John Deere 140 Kohler engine in reply to Gene Baratto, 10-29-2002 14:02:40
Gene, The later cranks used a bolt instead of a nut as the cranks were easier to produce. Also many of these engines were fitted with drive shafts for hydro-static transmissions and the old external threaded shaft would interfere with the coupling, so it was changed. I think the bolt is a 1/2"-20 grade 8 but check with your Kohler parts supplier.
Tom Shortsle
10-29-2002 17:13:37
Lincoln welders used a Kohler engine with a tappered crankshaft and a bolt to hold the flywheel.
mark
10-29-2002 17:08:33
I worked in L&G at a dealership several years ago. All 8 thru 16 horse Kohler motors used a fine threaded nut to hold the flywheel on. I once broke the threaded stud off that the nut went on to hold the flywheel. Probably what has happened to yours before you got the machine. I don't know what they have substituted in place of the nut, but they have probably drilled and tapped a bolt hole. Maybe metric,probably fine thread. Good luck, Mark..
Tom Shortsle
10-29-2002 17:06:42
A Kohler engine dealer can help you if you have the spec #'s off the engine.
