John Deere H carb question
JRH
10-28-2002 19:57:21
I just put a rebuilt carb on my H to replace the one with the stripped idle needle theads. It runs much better now except it will not idle down below about 600 or 700 rpm. I made sure the throttle would close all the way on the carb against the stop pin. The idle adjusting screw can be turned with in a few clicks of being seated completely closed and it still runs fast. Any ideas would be appreciated. Thanks much,
John
Clooney
10-29-2002 03:19:09
 Re: John Deere H carb question in reply to JRH, 10-28-2002 19:57:21
JRH, make sure the throttle plate is sealing all the way around [especially the ends], then make sure the throttle shaft bushings aren't worn, then make sure the throttle shaft bushings are pressed in flush with the carb throat wall [if not, air will flow around the ends of the throttle plate]. In some cases you will have to bend the idle stop pin to get a lower idle.
~If none of the above apply make sure you have the correct needles installed then go back into the carb.
~If you used drill bits on the passages & idle holes & weren't careful you could have enlarged passages & will have a hard time getting it to meter correctly. ~You should be able to stall it by turning the idle screw down to seated. ~It wouldn't hurt to check the ign timing, too much advance will make it idle higher.
JRH
10-29-2002 19:19:04
 Re: Re: John Deere H carb question in reply to Clooney, 10-29-2002 03:19:09
Thanks for the advice. Today I took the carb backto the person I bought it from and got a different one. Just my luck, it idles fine but I can't get it to run under load to save my rear end. He agreed to to give me my old carb and money back. So I guess I'm back to square one. The reason I wanted a different carb in the first place was the idle needle threads in the carb that came on the tractor are rusted out and won't hold the needle in place. The tractor ran good with this carb until vibration caused the needle to move.
