John Deere 80/820 question?
Rick
10-28-2002 14:48:10
How many plows can I pull and in what gear? Also would like to know is this a good tractor use on a saw mill?
BJ
10-28-2002 16:07:42
 Re: John Deere 80/820 question? in reply to Rick , 10-28-2002 14:48:10
Should be able to pull 4-14 in most conditions in third gear and running a sawmill is no problem had my 830 in a sawmill about 10 hours a month ago used about 15 gallons of fuel
Steven M
10-28-2002 15:30:23
I know of 80/820 tractors that are pulling 4 or 5 14inch plows. I go to lots of tractor shows. I see 80/820 running a saw mill. I think they do a realy good job at it. Don't let people tell you that a john Deere two cylinder tractor is not a good belt tractor. Most of the stories people tell about John Deere two cylinder tractors not working good on a belt is just BS I have used John Deere two cylinder tractors to run belt machinery for years! without a problem.
Dan-CA
10-30-2002 23:09:34
 Re: Re: John Deere 80/820 question? in reply to Steven M, 10-28-2002 15:30:23
When using the belt, be sure to ground the tractor with a chain on the drawbar to the ground. The belt will build up static electricity in the tractor. You might get knocked on your back side when you touch the tractor!
hunter
10-28-2002 19:54:29
1 in a 1,000 two cylinder tractors were
used on separators once 4 cyl. tractors
became available. It was not the horsepower
that was lacking - it was the ability to main-
tain constant speed. When 2 cyl tractors were
used they had flywheels the size of a most
JD tractors.
I've personally observed an AC WD-45 absolutely
shine on a 818NH two row chopper after a JD 70
diesel just was not doing the job.
It takes real green to not recognize the importance of a snappy running - well governed
tractor on the pto or belt. Now the drawbar was a different matter - I'll still remember how the
old "A" would hang in there in the tough going
or for that matter our 720 Diesel.
bill koob
Craig M
10-29-2002 09:08:32
 Re: Re: Re: John Deere 80/820 question? in reply to hunter, 10-28-2002 19:54:29
Guys I don't want to start a green red argument but my grandfather pulled his sawmill with an A John Deere for quite a few years and did not want to pull it with anything else. This is second hand info passed down to me from sitting in the shade and listening to my dad and grandad remember old times. Anyway a neighbor bought a load of logs over with a M Farmall and wanted my granfather to saw them. He said he would as soon as he send for the A JD which at another farm they had rented doing field work. The neighbor insisted on putting the farmall on the sawmill so they did. In the mean time my dad retrieved the A. When he got back my grandfather made the man move the farmall and put the A to the mill. They said the farmall turned the saw faster but bogged down when the saw was cutting but the A JD just kept on popping and the saw walked right thru the logs. Admittedly my dad said the farmall needed tuning up. But my point is that a two cylinder will run belt equipment. And surely if an A (it was a 49 gas model) will pull a sawmill an 80 or 820 should too.
Ralph
10-28-2002 22:36:13
My 820 will pull 4 x 16 @ 8" in second on old alfalfa sod that has been pastured. Heavy soil. The reason Deeres didn't see a lot of belt use was they had a much higher belt speed than other brands. Another was the clowns that would slap the trottle open. One or two power strokes and the slack end of the belt was on the ground. A fraction of a second later the cylinder on the machine would catch up on lay the other section of the belt on the ground.
Thats because you used a poor belt. It takes a good belt!!
10-29-2002 03:36:13
 Re: Re: Re: Re: John Deere 80/820 question? in reply to Ralph, 10-28-2002 22:36:13
G Taylor
10-29-2002 11:54:01
 Re: Re: Re: Re: Re: John Deere 80/820 question? in reply to Thats because you used a poor belt. It takes a good belt!!, 10-29-2002 03:36:13
Belt problems also occur during ego contests. Usually some what ever colour vs green starts overloading the equipment trying to stall the tractor and prove it substandard. The old two cylinder keeps lugging down to the last gasp where the other brands would have already stalled. At these kinds of overloads something is going to give.
