HEY Clooney, one more question
Brad
10-28-2002 07:38:33
Will a DLTX-53 carb off a JD A fit a 1950's JD B???
Clooney
10-29-2002 03:26:22
 Re: HEY Clooney, one more question in reply to Brad, 10-28-2002 07:38:33
Brad, the 53 is an all-fuel carb but should fit, if the B is healthy it should work but will be hard to get to meter correctly at all ranges & will be hard to adjust.
~Unless you have made other changes that require more carb air flow you won't gain much & will probably loose some lugging power.
