JD60 Orchard
Leon R
10-27-2002 18:02:27
I need a little help here. I am looking for someone with a JD60 Orchard that can take some measurements off the flywheel cover for me. I am restoring a 60 Orchard and as it never had a flywheel cover when I picked it up I acquired one from an AR which is the same except for the timeing hole and timeing hole cover. The ar cover doesn't have a timeing hole. I need to locate the exact position in the AR cover for the hole. If you can help please email me for further information.
Thanks.
Rman
10-27-2002 18:10:02
 Re: JD60 Orchard in reply to Leon R, 10-27-2002 18:02:27
Look in a manual if you have one. but i just put my 60 together and if the AR style has a center piece that you can remove you match up the marks on the flywheel with the mark on the inside of the cover(it should be right on the lip that the center piece snaps onto) hope this helps!!
Leon R
10-27-2002 19:54:05
 Re: Re: JD60 Orchard in reply to Rman, 10-27-2002 18:10:02
Thanks Rman. Is your 60 a mag type or distributor ignition? Mine is distributor and all the flywheel timing marks are on the edge of the flywheel so that a timing light can be used. I have the manual and it shows the timeing hole at about the 11 oclock position on the upper edge of the flyheel cover.
